An attempt to qualify the specified port has failed. The specified return code value is provided by the low level driver which has only internal significance.
This is an unexpected internal condition needing technical assistance. Contact technical support with the following information: - output of "show tech"
Error
Port %slotPort% qualification failed on slot %slot%, unit %unit% return code %rv%
| Name | Type |
| slotPort | SlotPort |
| slot | uInt |
| unit | uInt |
| rv | uInt |
